godamgo Well-known member Feb 18, 2008 #1 I'm thinking of getting a 16gb card, how easy is the process to upgrade the firmware and how long does it take to upgrade my hvx?
manglerBMX Veteran Feb 18, 2008 #2 takes maybe 10-15 mins. its very easy. here are the instructions https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft/hvx200/hvx200verup_e.pdf here is the download https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/soft/vsi4598g.zip conveniently located at http://panasonic.sixbullets.net/ where you can find all drivers and firmware updates for panny products.
David Saraceno Moderator Staff member Feb 18, 2008 #3 Really easy. Get atleast a 60 MB SD card and make certain you format it first in the cam
manglerBMX Veteran Feb 18, 2008 #5 read the instructions on the pdf. you need to format the sd card using the camera. insert the card. turn the cam on, go into mcr mode. menu>operation>format>sd card. then stick it in your computer and copy the necesary file onto it.
