A guy posted this comment over at Cineform's forum:
Apparently, the HV20 always insists on introducing a pulldown to the 24p for a 30fps playback. No matter what software you use to capture 24p from the HV20's tape, you must do a pullup to regain the 24p. But there is inherent artifacting due to the MPEG-2 tape conversion to 4:2:0, resulting in chroma bleed and the fields can not be completely eliminated by any capture or post pullup. There are ways of further processing the image to get rid of the artifacts but they only result in loss of vertical resolution. This all seems to defeat the purpose of an HDV 24p palmcorder unless you are always hooked to a computer and capture directly to disk from the CMOS thru the HDMI. Did I miss anything before I return the camera?
Curious what you guys think. Does the process of pulldown removal to get 24p cause this "chroma bleed" or other loss of image quality?
