oneinfiniteloop said:I like the idea of a general enviro PSA. I think we should take it as part of the challenge to make something informative, but NOT political...that's where your skills can come into play.
Just spread information, not politics.
Also, it would be cool to have some sort of general theme of it all, because if you open it up too much, there won't be a clear defined baseline to judge against.
Example: Create a 30-60 second PSA that deals with enviromental issues, and implements elements of conservation, responsibility, and awareness knowledge.
Just an example, but that would give the judges a criteria instead of objectively picking what they think is the 'best'.
Jack Daniel Stanley said:So just as I would keep the topic broad (envoronment vs. global warming) but within a certain ruberik, I would base the judging on
CONTENT "Does it inform OR advocate change OR awareness"
EXECUTION "Were the design, technical and acting choices well executed?"
OVERALL IMPACT "Did the execution gell with the contet to create a sharp impactful add that was clear and will stay with you"
Well - I think that's a call for Jarred, but I would be tempted, if Jarred would allow it, to open the gates on this one. So the MOd run Genre Fests remain limited to HVX / DVX but the user run Spec Fests are open, in the spirit of getting the best ideas out there regardless of what they are shot on.oneinfiniteloop said:Much better criteria, I was just throwing out those particular topics (responsibility, etc) as just ideas, not anything to go by, because I know I wouldn't want to be limited, but definately need something to judge against.
What about tech-wise, I'm assuming it will need to include some sort of DVX shot footage, correct?
