No visual difference.
If you're looking to grade very heavily then the HQ would have 10-bit advantages, standard ProRes being 8-bit, but for the most part you only need to encode to ProRes LT, which is plenty enough to accommodate the AVCCAM colourspace.
Anything over LT and you're just making a bigger filesize for no reason.
All ProRes formats are 10-bit.
LT is 100mbps, which is more than enough for AVCCAM
Good to know. I'm still using FCP 6 so I can't use LT or 4444 and didn't know the bitrates. You are right LT should be fine then.
Brian,
So you are using Pro Res HQ? I also have FCP 6 and wasn't sure which flavor to use. You're right, LT isn't an option in 6 but I saw many other Pro Res options available.
For a $245.00 update, you can get FCS3 if you shop.
You need an Intel Mac, but man it's a nice upgrade.
I have a new MAC Pro -- 12 cores, 16GB RAM, 8 TB storage -- so I thought 422(HQ) would be no problem.
Worked on two projects using L&T setting to 422(HQ) and the computer kept crashing. Changed it back to 422 and haven't had any problems since. Not sure if it was coincidence or not, maybe it was a third party plugin I was using. Either way it caused me a lot of anxiety with my rapidly approaching deadline.
Anyone else have problems with 422(HQ)?
Last time I used FCP 7 it had a lot of bugs. I use it sometimes when I'm doing RED stuff, I just use a friends MacBook Pro with it installed. I think I'm going to skip over version 7 myself. I heard a new version is coming out soon.
