Can someone please make this clear to me?
From the manual (Vol2):
30P mode:
Shoot 30 frames a second in the progressive mode. For output and recording, the 30-frame-per- second signal is converted to 60-field-per-second interlace.
This mode gives you high quality images.
24P mode:
Shoot 24 frames a second in the progressive mode. The video signal will be recorded natively. However, the external output signal is converted to a 2:3 format, 60 fps interlaced signal
If in 30P, you will get interlace in camera (to card) plus out to HDMI/SDI and in 24P you'll get Progressive in camera (on card) and interlace out to HDMI/SDI. Am I correct?
If this is correct, then using a nanoflash with all its bit rate will be... interlace? Or is there a way around that? Or am I wrong about the whole thing?
30P mode:
24P mode:
