Program to extract audio from slo mo clips
HpxRigal
Im filming in 720/30pn at 60 frames per second, is there a program i can use to extract the audio from each clip? Or is that not possible?
thanks
Could you explain what you are asking a little more clearly?
Are you recording pNative at a different frame rate?
If you're shooting int he PN modes at a frame rate other than default, there's no sound recorded, so there's no way to extract any audio. It's just not there.
Yes its when i'm recording at 60 frames that i was hoping to retrieve the audio (720p/30pn). i was under the impression it was possible...
If you really want the audio just record 720/60p and drop it into your 30p timeline. But as stated above theres no audio when recording off speed.
