Hey guys,
This may seem obvious but I would like to discuss the benefits of RAW data acquisition. There are a few things I am not entirely clear on that I would like to figure out.
The main benefit of shooting RAW, as I see it, is the ability to choose your working format after the fact. Whether that's DVCproHD or some other format.
What I don't fully understand are these:
1) How does lossy (RedCode RAW) compression work with RAW data? How does that affect the color sampling if at all? Am I right in assuming that RedCode is lossy? I understand how lossless RAW compression would work but not lossy. This is, of course, assuming that by RAW you mean the data that hasn't yet been demosaiced? I just can't seem to wrap my head around how to demosaic a lossy compressed RAW file.
2) What exactly defines the RGB gamut used in RED? Am I correct in assuming that this is, at the lowest level, the RGB filter itself? The bit depth of the internal processing shouldn't have any affect on the size of the gamut correct? Is it possible to work with this, probably very wide, gamut in post for, say, a film transfer? What sort of format would be capable of handling that?
3) The camera will have standard LUTs available for compressing this gamut to Rec 709 etc, correct? I believe I read this somewhere on the forums.
Maybe I'm just confusing myself thinking too hard here!
