lestimides
To begin with, I have fairly limited experience with P2.
I have been handed an external drive with P2 footage (presumably captured from P2 cards). Some of the main folders have both the CONTENTS folder and the LASTCLIP.txt file in them, and some only have the CONTENTS folder without the LASTCLIP.txt file.
I've tried bringing the footage into FCP through the FCP log and capture window. Some of the clips were converted to .mov clips just fine, and some were not. When I look into the Capture Scratch folder I see all of the clips I had tried to import. However, those under 4GB are showing up in FCP, while those that are said to be 4GB are not showing up. Nor are they playable in QT or in any other media player.
Now I know they are not all exactly 4GB large. So, it seems there is some problem with clips that are bigger than 4GB - they get cut off at 4GB and rendered unplayable.
Is this possible? Has anyone ever had that problem? Please help.
Thank you,
serge
Thank you,
serge
