Probably the most inexpensive "rig"
sirk
Hey folks,
I recently got to a hardware store and took my GH1 there and spent about 4 hours there looking for usefull stuff. What I came up is a pretty nice handle, a stabilizer and a focus/zoom puller. Ok, it doesn't look really good and has is cons, but hey, I could've spent hundrets of bucks for very basic tools. Look at this:
I added weight at the bottom of the "stabilizer" as you can see. I first experimented with weight straight under the camera, which made movement in two dimensions very smooth, but the problem was, that the camera rotated too easily around the pipe's axis. The solution was to add the weight far from the center. It much better now, just have to fix that weight.
I used standard pipes with pipe caps. I drilled holes into the caps and screwed the other small parts. I can give detailed information if anyone is interested.
There is one version! I'm looking for something just like your focus handle. How did you put it together? Love that giant screw :)
the puller is actually ONE part. You can get in in your hardware store I guess. Should be somewhere near pipes. The giant screw was attached afterwards (but that ring-part also has a hole for a screw, so basically it is a focus puller :)
Fantastic Sirk, and this works probably better than all that fancy overhyped expensive stuff everybody else is talking about :-)
