Print to Tape Problem Final Cut Pro
bentramer81
I can get the image to show on my camera for printing to tape, but when i press the record button it will not record, it does nothing. Do I need to put the camera on some special setting to print to tape?
I had the same problem recently....After a bit of a struggle found that my settings were a bit off. Double check your settings...I had to go to Final Cut Pro> Easy Setup> HDV> 24 fps. Also make sure your A1 is in play mode.
You shouldn't have to hit record. Go to File, Print to Video and in the dialog box that pops up, check the "automatically start recording" box at the bottom.
I hope this helps.
