Lumiere
I'm trying to get a set of primes for F3, i decided to go with Zeiss CP.2's. But my concern is which of them to get, as i 'm planning to get only the 7 of them. On the wide end i'll go with Duclos Tokina 11-16, and then the CP.2 set, 21,25,28,35,50,85,100. But today i thought maybe i should leave the 21, instead i should get 18,25,28...Between 18 and 21 there is not much, i believe i can compensate that range with 16 and 25.Which way would you go? And on the other hand 50mm has the same one with macro feature, instead of regular 50 would you get 50 macro so i have regular 50+macro feature (50 macro has different front diameter)?
Thanks in advance
Thanks in advance
