Ok I never tried this with the HVX 200 before. I'm trying to use the hHVX as a through put for a preview monitor from FCS 6.0.2. Heres my set up:
Media is DVCPRHD / 1080p/30
Media is already on FCS timeline.
I have firewire connected to the HVX from the Mac G5
I have the component output - out from the HVX to my preview monitor.
The preview shows up on the HVX LCD screen but not on the Preview monitor. If I switch to camera mode the preview works fine on the monitor. Also in FCS under : view/video playback- I only get a firewire ntsc option for preview... Should I not see an option for DVDPROHD ? ... Having only used this method for SD I assumed the HVX would work the same way as a through put...
Is it a possibility that I must use a KONA card for this?
Nava
Nava
