denzlite
So I'm following advice I read somewhere ... since the AC90 breaks up long clips you should copy the whole PRIVATE folder to the HD and then use Premiere to import so you don't get that glitch/gap thing. Inside Premiere I just go to Media Browswer/HD/Footage/AVCHD and wa-la - there is all the footage as if it's contained in one file.
This method is causing tremendous headache in Premiere - taking forever to load frames when moving playback head - terrible playback.
When I go File>Import and drill down to the STREAM folder on my HD to get the various .MTS files - no performance issues. Does this make sense? Any workaround? I'm on a Macbook Pro - awesome specs.
