Premiere Pro 3.10 and Raylight
Ursa
Hi!
I'm sitting here wondering if I should download the PP 3.10 update and get P2 support. The only thing I'm wondering is: Is the Premiere native support WITH "flip effect" (for 35mm adapter footage) faster than Raylight?
Your help is appreciated! Thanks :)
When I used p.pro 3.1 it had slightly better performance than Raylight, however it will not automatically flip all of your footage!
You'll need to basically rotate everything 180 through the motion plugin applied to each clip, and then you'll have to copy and paste the effect to all of your clips.
As far as I know, there is no way to view your footage while you are cutting it, upright.
Hi!
You might want to wait until this is available: http://dvfilm.com/MXFX
It will preprocess clips and flip without recompression. This
way your thumbnails will be right side up and you can also view
the clips in P2 Viewer and the NLE's viewer right side up.
