I've been trying to get Premiere Pro CS5 to crop and scale a 1280x720 60p video to an NTSC DV 24p video at 720x480 using the Quicktime export dialog. You'd think this would be straightforward, and the dialog box makes it look routine. I set the crop specs in the Export Setting's Source tab, and in the Output tab, the video is visibly cropped the way I want it. Everything else in the dialog looks correct for a Quicktime export to a DV/NTSC 720x480 24p file.
Yet, when I either Queue it to AME or Export it directly, the rendered MOV file does not contain the cropped frame displayed in the Export Settings dialog. It contains a downscaled, letterboxed render of the original 1280x720 video without the correct crop settings. What's going on here, Adobe? Is this a blatant interface bug or what?
