I asked the same question when I bought my C100 in 10/13. I wanted it to be a DSLR so I'd have the stills capability but most importantly I wanted the sensor size to be as close to the C100 as possible so I could use the DSLR almost like a director's viewfinder. I took the 70D on two long vacations and got to the point that I could look at a situation and guess which focal length would be best on the C100. I have not yet used it as a B-camera, I understand from previous posts it is important to upload the profile called Technicolor.
The way I settled on the 70D is I wrote customer service at Lensrental.com asking which DSLR would most closely match the C100 and the following is what they wrote back. Also very importantly, the new AF feature in the C100 is the exact same feature as the 70D, so with my DSLR I have been practicing changing the focus zone away from the center of the frame which will be crucial once I get my AF upgrade. Here's what they wrote:
The Canon 70D has an ASP-C sensor (x1.6 Crop) which is similar to the Super 35 sensor (1.5x crop) of the C100. The 70D's sensor will allow you to capture images with a similar field of view to that of the C100, while functioning first and foremost as a still picture camera. The dynamic range and low light functionality of the C100 is better than that of the 70D, but there currently aren't any DSLRs available that can match the C100 in dynamic range and low light, in video mode. I suggested the 70D because it's functionality and quality of image can't be beat at that price. Another good option is the Canon 5DmkIII. Although the 5DmkIII has a full frame sensor, it's footage will match well with the C100. The 5DmkIII will give you slightly more dynamic range and low light performance, but still won't match the video specs of the C100. It also prices more expensive than the 70D.
http://www.lensrentals.com/rent/canon/cameras/canon-eos-70d
http://www.lensrentals.com/rent/canon/cameras/canon-eos-5d-mark-iii
But you should do a Google search of the subject starting with the term dvxuser.com because you will get more info than just reading short rehashes of what we talked about previously.
Well, hoping (HOPING) that the Metabones EF mount Mk3 will step in here. So long as you've got FF lenses (e.g. 24-105, 70-200) they too would work on the A7S. Even Tokina 11-16 should work on A7S at 16mm only.
But you should do a Google search of the subject starting with the term dvxuser.com because you will get more info than just reading short rehashes of what we talked about previously. Better yet, do what I did. Go to the first C100 post in this forum and read through, cutting and pasting from the experts such as Erik Naso, Ben Giles, Dustylense, Matt Turner, etc....If you post and ask for info you will miss so much. When the C100 was new there was a flurry of experimentatin and results were posted so go back to the original start. I am having trouble with mixed WB and the C100 and am about to post a question but first I will do an archival search. Many experts are tired of answering the same question so researching first is best.
it's still (IIRC) an 8 bit device, and that weighs heavy upon my soul.
