Tim Nitsch
So I've been considering switching to V-Mount batteries to power my C100 (and other accessories) and I just wanted to double check a couple things.
The battery I'm considering is the Switronix XP-L90s: http://www.bhphotovideo.com/c/produ...x_XP_L90S_XPL_90S_V_Type_14_4VDC_Lithium.html
According to the manual, the C100 draws 8.1 watts per hour.
So if have this right, a 98wh battery would power it for 12 hours correct?
98 / 8.1 = 12.1
It also says the C100 requires 8.4v DC.
But because V-Mounts are usually 14.8v, I would need to convert it to 8.4v to avoid smoking the camera.
The V-Mount plate I'm looking at has multiple outputs, one being an 8v option.
Tilta V-Mount Plate: http://www.bhphotovideo.com/c/product/1007351-STUD/ikan_bt_003_a_power_supply_system_for.html
Would that 8v output work or does it specifically need to be 8.4v?
I also saw this Ikan V-Mount Plate:
http://www.bhphotovideo.com/c/product/1080480-REG/ikan_ipd_s_power_dock_with_v_mount.html
It doesn't have an 8v output but it does have an 7.4v output (same as the BP batteries). Would that work?
98 / 8.1 = 12.1
