I've been testing out my AF100 for the past few days and most of the stuff I am shooting is on the run and my tripod is really slowing me down. Anyone have a suggestion on a good monopod to be used with the Af100?
I'm also looking into a Glidecam HD as well. thoughts?
If you're moving between the monopod and the sticks frequently, consider using the same brand of both, so the plate is compatible.
Check the monopod recommendations by stillmotion on their blog. Also check out blackbird for stabiliztion.
Thanks for the recommendation. I was looking at either the Merlin or Glidecam but now I have a third option.
I was leaning toward the Merlin but I read it isn't as sturdy and holds less weight than the Glidecam. I like the form factor though and many swear by it. Blackbird looks good and priced well. At the moment, I don't have the budget to purchase a vest.
I'm having a hard time deciding on which to get. I would rather try them out before making my purchase but I cant find a place near me that rents them out - and I dont want to do the whole shipping/renting/shipping back route. Has anyone used these stabilizers with their AF100? Even better, has anyone used 2 or 3 of these and can make a recommendation on which works better with the Af100?
I read that the Merlin (even with its arm) can only hold up to 7 pounds; whereas the Glidecam can do up to 10 without the arm and 18 with it. Is this true? Why would there be such a wide gap between two similar/competing products? I was leaning towards the Merlin but I want to make sure in the long term it can hold all my attachments I have for my Af100.
It's all about counter weight. The Glidecam does have a longer stem, in essence creating more inertia. The Blackbird's neck is also extendable and like the other two, can add more counter weight. 8 pounds does get heavy so unless it's quick bursts of shooting, an arm may be better. Have you weighed the AF100 with all your attachments? With steadicams, you don't want to use long lenses. The 20mm 1.7 is pretty nice on the camera and is light. To prevent lens flares, you can make a quick and dirtly lens hood. As soon as you add matte boxes and rods, the weight adds up quickly.
I haven't weighted it just yet. Right now, I have a Redrock baseplate/follow focus and some Zeiss ZF2 lenses. But I am also planning to purchase a matte box later down the line. I just want to make sure I invest in something that will last me (and eventually get a vest/arm). And also something that is reasonable in cost (ie I cant afford a Pilot)
If you are going to use all that gear on a stabilizer, then stepping up to the pilot is a better choice. On a side note, unless you have remote focus, having the FF on there is useless. Strip it down, and the merlin, glidecam, blackbird, are surprisingly very capable gear. Besides, this type of shots are not really bread and butter. Rent if you have to and put the money into glass.
+1*** NOTE: There is a new version of the Manfrotto 561BHDV monopod the model number now has a "-1" added to it. ( 561BHDV-1 ) The new version has a "RED" panning socket at the base of the monopod, and it has been redesigned to overcome the "sticky" problems when panning with the old version. I have the old version and I hope that Manfrotto comes out with an upgrade kit for owners of the old model.
I like the 561 also. Great little monopod that even can stand on it's own.
