SonsOfMatthew
Hi guys, please can you kindly recommend a good and ideal adaptor that will enable me use another lens mount on a the PL mount of my Sony F35.
Thanks a lot guys.
Thanks a lot guys.
Thanks a lot guys.
Duct tape
Duct tape
He is not joking. It does the job.
Haha, I am half serious. it helps in figuring out a game plan at least.thanks, will give it a go....
Thanks, will still give it a go.
Simply looking for a solution to use readily available modern lenses, vintage lenses as well for reasonable prices.
There are more and more cheap PL's available all the time, so it can be cheaper to. go that route.
But if you take the screws out and remove the PL mount you'll see you can easily bolt some other mount on there. The issue is flange discount and the diameter of the opening. However, if you are good with machining or 3D printing, you cold make your own faceplate and bolt the sensor block onto that. Might save you several millimeters and allow you to put an EF mount on there.
Also, if you are really handy, you could replace the IR filter and take apart a speed booster and shove the lens element in front of the sensor and turn the F35 into a Full frame CCD camera.
I don’t follow.Like how handy? I mean in the measurement of handyness being what? speedboost what?
The camera you purchased was at one time developed and meant to be used by the 1% (Hollywood), and the only mount in that world is the PL mount.
Hahaha, every one trying to make the F35 something else. 4K, IMAX, speedboosters, duct tape and super glue... let her live, let her breathe people!!!
You could find a cheap/used PL lens to get started if you were planning on doing more than a few tests here and there with tape.
