C100: PL adapter for the C100
You'd better have a way to support the lens on some time of iris rods.
The EF mount can't take anywhere near the torque that some larger pl glass will put on them with an adapter.
interesting that that one has you remove the canon mount. wonder if that difference is appreciable vs the plain ef mount ones.
but do you think that would be enough for simple primes ? (like CP2s)
because I always see that the CP2 with EF mount moves a little bit...so I use a mattebox on rods to make it solid. That works but...I prefer using clip-on that mattebox on rods (faster, to me), but that's not possible with the EF mount :
for exemple if you use a motor for a wireless follow focus, the lens will slightly move if you focus back and forth...and that can be more than noticeable with a long lens like a 135mm.
