I hadn't noticed that. I kind of assumed since the lens specs seemed the same as the UX180 they might have similar hardware.UX180 and DVX200 both have Leica-Dicomar lenses, so I'm wondering why not the CX350. Although, they seem like the same lens specs.
Is the handle removable? If not, I may have to wait for an upgrade to the fz2500 and hope that it has internal 422 capabilities.
It has Infrared recording just like the UX180.Anyone know if these have a night shot mode like the UX180?
Both. 3/8, then a positioning socket, then 1/4.
No, going into super-slow requires a few seconds. It's one button press when shooting 1080, but when shooting UHD it requires a menu change. Either way it takes a few seconds.Can you move quickly from UHD to HD120?
Yes, it can do 1, 2, 4, 6, 9, 12, 15, 18 fps etc. It also has real time lapse, 1 frame every second on up to 1 frame every 10 minutes.Does it have low FPS for faux timeplase?
Can that be engaged quickly?
Here are just a few things that Panasonic got exactly right with the CX350, especially when considering some of the limitations that have been present in the last few generations of cameras:
1) The LCD and the EVF both work at the same time.
2) The HDMI and the SDI both work at the same time.
3) The magnified focus assist works even while recording.
4) The hybrid 5-axis optical image stabilization works even in 4K/UHD.
5) It's compact and lightweight, even a little smaller than the UX180.
6) It has a 20x zoom lens, with zero frame size changing or cropping going on. All resolutions and frame sizes are all the same field of view.
7) The i.Zoom is a "lossless" crop on the sensor that results in extending the focal length; it's 24x in UHD and 32x in FHD. i.Zoom hasn't worked in UHD on prior cameras.
8) The menu navigation is so much easier on this camera, because there's a full pad of buttons that can be used for up/down/left/right as well as touchscreen and wheel navigation.
9) The waveform monitor doesn't take over the whole screen, it doesn't make the other displays disappear, it's just an additional display like you'd want it to be.
10) When shooting UHD, the HDMI output doesn't have to change down to HD, it can continue outputting the same signal it was during standby.
There are just so many things that work exactly like they're supposed to. In the last few years there have been some workarounds necessary because the chipsets being used didn't support mixing certain features or whatever. It's like all those have been swept away in the CX350, and instead the camera just works exactly the way you'd always wanted it to, without any odd limitations or workarounds. That's why I say it's like a "greatest hits" of Panasonic camcorders, all the best features from all the best cameras are all combined in this one unit.
Hey Barry, I'm not sure but it seems that the AG-CX350's lens is not a Leica, so it should be manufactured by only Panasonic. This is the first time that I didn't see a Leica logo on it (but maybe I've missed the right picture) , how does it performs?
3. Where are the lenses manufactured?
ZEISS still picture lenses are manufactured in Japan and ZEISS cine lenses in ZEISS’s factory in Oberkochen, Germany. It is still economical for ZEISS to produce its cine lenses in Germany due to the more sophisticated skills required to manufacture these special lenses for the film industry. To satisfy the much higher global demand for still picture lenses, ZEISS has established a partner network in the optics industry. During the entire development and production processes, ZEISS experts ensure that the high-quality standards for which ZEISS has been famous for over 165 years are met.
Sony/ZEISS lenses are manufactured by Sony in factories across Asia. In these factories Sony uses lens testing equipment that has been developed and manufactured by ZEISS. An example is the MTF-tester K8, a versatile and compact instrument used to measure the modulation transfer function of photographic lenses, or similar systems, at an infinite object distance.
This is all my opinion, not anything from Panasonic. If I'm totally off base I'm sure Mitch will correct me.
