That's a very usual thing if I am to understand you correctly the camera has no view finder. So settings overlay is not being sent to the video out so you can't see the menu? If you found a diagram of the menu tree you could either attempt to turn the overlay on or change the frame rate blindly. I assume you are recording the video out. Good luck!
Hello, does anyone know how to access the camera settings on the external monitor?, I don't have the eye piece to where it would show up, and i'm trying to change the settings along with the frame rate.
You may or may not know this. If... and this is a big if, if the menu has been assigned to either the video or monitor out pressing down the menu button for three seconds or more should display the menu on whatever output it has been assigned to. If you hold the menu and LIGHT button down together you should see the option menu. The button presses must be a good three seconds to activate the menu out function. Good luck!
Chris Young
Chris Young
Update, it worked I had to constantly push light and reset, Thank you
