MQ is the master tape that Pansonic makes.. its a white tape (very good becase you can always find them in the bottom of the bag, and label them with a sharpy marker without a label) and come in a nice plyable case (no more cracked cases) Not to mention they are the densest tapes in particle count which means a very low dropout rate.
DID I JUST HEAR YOU SAY THAT FUJI IS DRY TAPE?/ IS THIS CORRECT? i HAVE FUJI LAYING AROUND USED FOR MY OTHER CAMS. BEEN BUYING PANNY TAPES CAUSE THEIR DRY..
[quote author=Fred_Plowman link=board=Events;num=1089782130;start=0#7 date=07/14/04 at 11:54:24]Hey JARRED,
[quote author=Jarred Land link=board=Events;num=1089782130;start=0#1 date=07/13/04 at 22:19:32]They use dry, which alot of companies use like Fuji. [/quote]
[quote author=Jarred Land link=board=Events;num=1089782130;start=0#12 date=07/14/04 at 23:48:25]Just beware of the MAxells.. they are made by whichever factory has "leftovers"[/quote]
Jarred,
Hi, I'm new to the forum. I'm just about to start shooting my second feature with the DVX100.
I'm a little confused on this tape stock issue. When you say that Fuji uses a dry lubricant on their tapes, do you mean that ALL of their tapes use that, or is it just certain models?
I'm trying to save a little money by buying tapes in bulk from tapestockonline.com. They have the professional quality Panasonic tapes (PQ and MQ) but they range from $4.50 to $5.30 apiece, whereas the Fuji tapes (they only have one model, Fuji DVM-60) are about $3.10 apiece. Are these Fuji tapes okay to use in the DVX-100?
Anyone know if TDK ME tapes are dry or wet? I have a bunch from a long time ago, and was wondering if I should be leary of pulling any footage off of them.
[quote author=Jarred Land link=board=Events;num=1089782130;start=0#3 date=07/13/04 at 22:24:17]MQ is the master tape that Pansonic makes.. its a white tape (very good becase you can always find them in the bottom of the bag, and label them with a sharpy marker without a label) and come in a nice plyable case (no more cracked cases)[/quote]
yes, I think people underappreciate the time it saves just writing right on the tape... and the soft case is a huge improvement.
[quote author=Jarred Land link=board=Events;num=1089782130;start=0#3 date=07/13/04 at 22:24:17]Not to mention they are the densest tapes in particle count which means a very low dropout rate.[/quote]
[quote author=bizzlejig link=board=Events;num=1089782130;start=15#16 date=07/15/04 at 21:45:40]I'm trying to save a little money by buying tapes in bulk from tapestockonline.com. They have the professional quality Panasonic tapes (PQ and MQ) but they range from $4.50 to $5.30 apiece, whereas the Fuji tapes (they only have one model, Fuji DVM-60) are about $3.10 apiece. [/quote]
Next to batteries (AA & 9V), tape is the cheapest thing you use. Is it really worth it to save two bucks a tape and take on some risk?
