I want to love Vimeo but it's hard. You can download source video but the streaming and upload is slllooowwww and stuttery.
Odd, Vimeo works fine for me.
Personally, I've just never seen a YouTube clip that looks as good as most of the stuff I've watched on Vimeo. I also watch Vimeo on my 50" Full HD Plasma and it looks amazing. Even on a regular 27" computer monitor I've never seen YouTube's 1080p quality come close to Vimeo.
Why do you say it is far inferior? Except for the bit rate, wherein Vimeo tops out at 10Mbit whereas Youtube tops out at 8Mbit, they use the same encoding scheme. If you move up to more professional accounts, Youtubes bitrate far supersedes Vimeo, by 30Mbps! (50Mbit/20Mbit)
But if you want to upload 1080p to Vimeo, you need a Plus or Pro account. So why not opt for Youtubes higher level accounts and get the superior bit rate.
It's compression is far inferior to say Vimeo.
Not in my experience. Vimeo sucks so bad I gave it up and went solely with YouTube. Plus, you have to pay to get 1080 with Vimeo, and it seems like most people don't. So you not only get inferior compression, but only 720 out of the original 1080.
When you use a downloader plugin for youtube, you aren't getting the source video. You're getting the same video that youtube is streaming.I find both YouTube and Vimeo great, but ONLY if you download and view the source video. ( or the nearest facsimile to the source, via one of the YouTube Video Downloader plug-ins )
That's why I posted the comment "or the nearest facsimile to the source".
I still find the quality of YouTube videos MUCH better when you watch them from the downloaded video, which may be the result of better decoding from the current VLC media player that I'm using.
Unlikely, decoded video shouldn't vary by player
Try using a few different players and you will definitely see a difference in image quality. Generally the VLC media player seems to do the best job with my Windows 7 workstation.
I was a New Media developer for 10 years and worked mainly in Director and Flash, I currently use 4 different web browsers, though most of the time I use Chrome these days. ( Opera used to be my standard, but they're now developing with the Chrome platform and haven't fully ported all of their Opera features to the new platform. Currently I'm testing the Opera 19 Developer browser right now. )
I still stand by what I stated, where I find the downloaded video files produce higher quality playback when used with the VLC media player than any of the streaming Flash browser plug-ins.
I understand that you have experience with multiple browsers (and I think its funny that you keep name dropping Opera)
but my background in computer science & engineering can't help calling shenanigans. The file should not look significantly different once downloaded, especially since VLC is based on the same open source libraries for h.264 playback
Encoders are where the real difference takes place
It shouldn't matter which decoder is used, its the encoder that makes the difference.
I understand that you have experience with multiple browsers (and I think its funny that you keep name dropping Opera), but my background in computer science & engineering can't help calling shenanigans. The file should not look significantly different once downloaded, especially since VLC is based on the same open source libraries for h.264 playback.
Encoders are where the real difference takes place- Their job is to take the full resolution image and figure out a way to fit it within the required bitrate while following the rules of h.264. Sort of like a good accountant versus a bad one: If you bring your documents to a mediocre accountant, he will follow the rules and get you a certain amount of money back on your taxes (hopefully!). If you bring them to an excellent accountant, he will follow the same rules, but know all the tricks and loopholes to get more of a return. Both are following the guidelines of the IRS, but one does a better job and is more efficient.
A good encoder will compress more detail into the stream while still being compatible with any h.264 decoder. It shouldn't matter which decoder is used, its the encoder that makes the difference.
Now, I'm not saying every player will look 100% equal- sometimes one does a better job upscaling to fill the screen. Sometimes the gamma balance or color flags are interpreted differently. Sometimes real-time decoding is negatively effected by hiccups in the stream or the CPU can't keep up with the decoding thread (bits of data can be discarded in those situations to keep the stream running in real time), but the data that is in that stream will not change.
So, if you have a healthy computer setup, a good network connection and decent player (heck, try bypassing flash and run youtube in HTML5 mode), the detail displayed in the stream should not change. And if it does, there is something awry.
I really like that the GX7 has in-camera image stabilization.....
For still images only.
I didn't see that mentioned in any of the product descriptions that I read. If that's true then it's a major disappointment.
Decodes are just like encoders and not all programs use them the same even if there are built off the same library. That would be like saying all programs built off of Microsoft DirectX function exactly the same. We know that isn't true and sometimes when there is an API involved people implement that differently.
You are mostly correct, as I understand it. And I even admitted this:But it all depends on how those libraries are being used by the player, and in some cases the players are using their own CODEC libraries instead of the system CODEC libraries. In theory all playback should look the same if all players are using the same CODEC libraries with the same settings, but I'm not seeing this when I test the same video files with different media players, so I am pretty certain that things are not being handled the same way under the hood.
I'm aware. My background is in Computer Science and engineering. I studied this stuff and wrote papers on codecs in college before some of this was even around.I've been using the professional Sorensen Squeeze encoder encoder since version 2 was released in the late 90's ( Flash's Spark CODEC was invented by Sorenson along with their Sorensen Pro 3 CODEC which was also used by Flash at one point), along with the Canopus ProCoder ( now owned by GrassValley ), TMPGEnc ( for MPEG-1 encoding in the late 90's ), and On2's FlixPro encoder for FLV encoding. ( On2 invented the Flash FLV format that was essentially a repackaging of their VP6 format. The superior TrueMotion VP7 CODEC went nowhere, then the TrueMotion VP8 CODEC was gobbled up by Google when they bought On2 in 2010 and turned into an Open-Source platform )
I think that has less to do with decoding the image as it does with things like de-interlacing, scaling, gamma and color translation, etc. I'd like to think that internally the standalone boxes at some point get the same information extracted from the stream, then they go different ways with it.This is one of the key reasons why different DVD and Blu-Ray players can offer a different level of quality. In theory they should all just use mpeg2 or mpeg4 decoding and should look exactly the same but sadly that is not the case.
