joe12south
In addition to the scaling, the other big change is the removal of the OLPF. I haven't yet seen a moire-prone 4K sample, so not drawing any conclusions, but this is definitely something to watch-out for. Nothing is ever free...the bump in sharpness may have trade-offs.4k on the GH4 always looked cleaner because there was no scaling of the sensor. A perfect 1:1 output. The GH5 is a bit different this time which is why some have a concern. The full sensor is being scaled to 4k. So far all the 4k material I have downloaded from the GH5 looks great without any of the issues I was concerned about. Its still too early to know for sure if the down conversion method the GH5 is using will not have any aliasing or moire at all but so far so good. VFR is a pretty big down conversion from the full sensor and we don't know what corners have to be cut in order to process 180 frames per second. Sometimes the GH4 uses different down conversion methods based on how much extra processing the camera has to do. Thats why 96fps 1080p looked worse than 1080p FHD at up to 60 fps. different scaling methods were used to cut down on processor load. 60p is a normal functionality of the camera so it should always look at good as 30p or 24p. It is beyond that where things tend to get a bit funky.
Honestly the 180 fps is more of a gravy feature for me anyways. Cool to have it when needed but if I'm concerned about quality which is why I use a 4k camera in the first place then I'm not likely to use very much. With that said not all the shots at 180fps looked all that bad and I think they look much better than how the 96fps looked on the GH4. On the GH5 it seems to be more of just a high frequency detail issue vs just a really bad down conversion. Overall outside of some potential aliasing of extreme fine detailed patterns I think it looks pretty clean.
