No you're not alone and one of the features of the EVA1 that i'm hoping to see some samples of, are its 2k mode. first, i'm glad it's actually 2k and not HD since i do a lot of theatrical screenings of my work at film festivals. happy to avoid the minor blow-up i usually have to do. second, 2k is non-cropped, 10-bit, and 422 up to 120fps in the EVA1. hopes are high. the thing that disappoints (and it's my own fault) is that I assumed Dual ISO meant 2500 would be just as clean as 800. and that perhaps 3200 and higher would be acceptbale. that won't be the case apparently. what Dual ISO likely means is that you are shifting the ISO where DR is at its best, albeit noisier -- but again, i'm assuming.![]()
Unfortunately there is no difference between shooting @2k or downsampling 4k -> 2K in post on the LT. The sensor is S35 4k, can't go against it, vs the softer S35 2.8k on the Alexa. Concerning dual ISO it is obviously a bit noisier on the LT @5000, but the grain is gorgeous, and as you still maintain great colors and DR, the image looks fantastic. Most cameras exhibit terrible colors and DR as you increase the iso. I'm sure it will be good on the EVA1 @2500.
