Hello,
We posted here because we´re experiencing unexplained problems with two of our Panasonic Ag-af100 but we´re not sure if our problems occurs because of the cold weather or something else. One of the two cameras were in Panasonic repairs in UK, but they found absolutely nothing wrong with the camera after running a test for two days. Also we are not able to replicate the problem when we need to demonstrate it. First check out the video links below to see the artifacts we´re getting somewhat randomly;
Video1:
http://vimeo.com/35688019
Video2:
http://vimeo.com/36483136 (the video might be still encoding in Vimeo as I post this...)
So basically we´re getting red horizontal area/lines/artifacts overlaying the video. First we thought it might be something to do with the censor, but since the problem does not occur on every clip and situation, it doesn´t seem to be the right answer. It seems that this only happens when we have something dark (almost black) in foreground and very bright (over exposured) areas in the background, actually the most common situation is seen on the video where man is sitting inside the car (Video1). This is almost same as how CCD censors handle with overly bright spotlights... We get this now very often in similar situations. What is even more weird is when shooting inside the car and wide angle lens is moved or zoomed in (Video2) the artifacts seems to react to that. When we zoom in just a little bit the artifacts might change in width or disappear. We have tried different ways of over exposing and flaring the videos but are unable to replicate the problem. We came in to the conclusion that it might be the cold weather (example: 2hours in -20 celsius) we´re forced to shoot in the winter time since we could not see this problem in the summer time. Or maybe the problems is the memory cards we´re using? We really hope that somebody could replicate this problem because we´re out of ideas at the moment.
Here is the setup we are using when the problem occurs:
Panasonic Ag-Af100 (With the latest firmware, happens with both of the cameras)
Lumix G-Vario 14-140mm f/4-5.8 Asph.
Lumix G-Vario 7-14mm f/4 Asph.
Transcend SD HC (10) 32gb
I don´t know what in camera setting were used, but it doesn´t seem to relate the in camera settings.
Sincerely
Mikko Miettinen
T-Magazines
Video1:
Video2:
Sincerely
Mikko Miettinen
T-Magazines
