Panasonic AC130 and AC160
Thought it might be nice to have a new thread dedicated to these new cams
AG AC 130
Sensor: Full HD 3 CMOS 2.2MP chips
Lens: wide angle (28mm) 21x with 3 rings for iris/ focus/zoom
Format: AVCHD and DV
Inputs/Outputs: HDMI and firewire, USB 2.0, RCA audio out, 2 remote terminals, 2 xlr jacks
ND Filters: 4 selections
Framerates: 1080 60i 1080 30P 1080 24PN 720 60P 30P 720 24PN DV 480 60i 480 30P 480 24P
LCD: 3.4 inches 922,000 dots
VF: Over 1MP
Audio: Dolby digital
Special: Timecode, time date stamp, waveform ,vectorscope, twin card slots with support for SDXC and simultaneous recording, 3 programmable user buttons
slow shutter and synchro scan...the usual Panasonic goodies.
Form factor: 5.5Lbs...so it's a bigger camera.
AG AC160
All of the above but add HD SDI, PAL/NTSC switchability, Linear PCM Audio, and VFR recording.
I love these cameras!!
Can anyone check for me if the AC130/AC160 has RCA video out? I want t oknow if it'll be compatible with the Steadicam Pilot stage and monitor which only feature RCA video.
I'm interested in knowing the prices of the 160 compared with the 250. Both essentially the same, but P2 vs SD and AVCIntra vs AVCCAM. Is that price gap $1000? $2000?
Hi,
First, I am missing the Enemy 130 or spooky/specter reference. Can someone explain? Thanks, maybe it is just not enough coffee yet.
So yes it they all have a SD Video out and HDMI out. The 160 has HD-SDI out.
The Pricing:
The AC130 under $4000
The AC160 under $5500
The HPX250 under $6500
Best,
Jan
The AC-130 is the model number of a US Air Force warplane that you can use to attack military targets on the ground. Many of us DVX users have probably chopped up a lot of enemy infantry and vehicles in the Call of Duty video game series with an AC-130. The actual warplane did some serious damage in the Afghanistan as well. Some war vets refer to it as "flying death on black wings." But you probably won't be able to wiki that reference.
Hi,
The Pricing:
Best,
Jan
Thanks Jan!
It seems to me for $1000, it's totally probly worth the cost unless you don't dig P2 cost. The dual slot SD recording is boss, and slightly negates some of p2's advantage. Good stuff with both cams though.
That is a bit of a decision. 10-bit AVC-Intra at 4:2:2, vs. 8-bit AVCHD at 4:2:0 but on cheaper memory cards that can be simultaneously recorded. I think the AC160 would be the events camera of choice for someone who has to hand off media to the client at the end of the day -- you can keep one card for yourself if the client (invariably) loses it, deletes stuff, formats it, or complains that you didn't give them the right footage, or whatever -- you'd have a backup. For those that are already integrated into a P2 workflow or who need 4:2:2 or 10-bit or AVC-Intra, the HPX250 would be the obvious choice. And for those who can't afford either or who don't need all that the top two offer, the AC130 gives you most of the goods for quite a bit less.
I asked and was told that they will both have RCA composite video outputs.
Hi Jan,
The cameras of the Panasonic were the last options we had to work with ccd, cmos sensor now with the new release, we have to swallow the problems with rolling shutter?
First, they are MOS sensors not CMOS, yes there is a difference. You can clock the MOS sensor a little faster, or so I am told, and due to structure, each pixel has a larger surface area for gathering images. The sensor used in these cameras are very good, it is the same sensor in the HPX370 which has very low skew. At this point though I think the HPX170 will continue in the product line as it iwill be the least expensive entry level P2 camera.
Best,
Jan
Best,
Jan
Ok so it is indeed the EXACT same sensor in the HPX370.
Cool.
I must say that Panasonic has come out with my dream camera.
I was thinking of moving the switch to HD but I didnt like the up/donwrezzed stuff everyone had at the time but now I get full raster chips in an ergonomic form factor i adore (and for a price I can manage).
Thanks Pany!
One question: What f-stop are the lenses of these new cameras? With the same 21X zoom range I hope it also boasts a 1.6/1.8 aperture.
