PappasArts
FOR UPDATES #MIKOS • MIKOS ARTS on Twitter
http://Twitter.com/pappasarts
http://PappasArts.com
http://MIKOSarts.com
http://LHOart.com
http://LHOarts.com
http://LHOarts.net
#MIKOS
http://Twitter.com/PappasArts
http://LHOart.com
http://LHOarts.com
http://MIKOS.info
http://LHOarts.net
MIKOS
[size=+1]BlackMagic Digital Camera Info:[/size] http://www.bmcuser.com/showthread.p...mera-Technology-Announcements-amp-Latest-Info
http://LHOart.com
http://LHOarts.com
http://LHOarts.net
[size=+3]PANASONIC'S 4K CAMERA SYSTEMS[/size]
[size=+0]Panasonic is proud to introduce an ultimate photo/video hybrid Digital Single Lens Mirrorless(DSLM) camera DMC-GH4 for the successor of DMC-GH3 that created an industrial sensation with its outstanding video recording performance. The image quality for both photo and video is dramatically improved by crystallizing Panasonic’s cutting-edge technologies.[/size]
The newly developed 16.05-megapixel Digital Live MOS Sensor for DMC-GH4 excels both in sensitivity and response and suppresses rolling shutter effect even when using electronic shutter or recording motion image. The image processor Venus Engine is also newly developed dramatically boosting its performance with new quad-core CPU that lets high speed signal processing required for rich video recording such as 4K. Integrating superior noise reduction systems, DMC-GH4 enables shooting at max.ISO25600. Sensitivity, gradation performance, resolution and color reproduction are dramatically improved to achieve even higher picture quality. The DMC-GH4 boasts high speed burst shooting at 12 fps(AFS) up to approx.40 (including RAW) / approx.100 (excluding RAW) and 7.0 fps(AFC) to capture fast moving subject just in-focus.
The new DMC-GH4 further evolves to bridge the gap of consumer video camera and professional video camera. One of the most prominent advance is unlimited*1 4K video recording (Cinema 4K: 4096×2160 / 24 fps and QFHD 4K: 3840×2160 / up to 30 fps) in MOV/MP4*2. The DMC-GH4 is also capable of recording Full- HD video with ultra high bitrate at 200 Mbps (ALL-Intra) or 100 Mbps (IPB) without recording time limit *1*2. Users can freely choose the format from MOV, MP4, AVCHD Progressive and AVCHD at a variety of frame rates according to the usage. For the global business of professional users, the system frequency can be flexibly selectable between 59.94Hz (23.98Hz) / 50.00Hz / 24.00Hz. The DMC-GH4 is also capable of real-time image output to the external monitor via an optional micro HDMI cable simultaneously while recording video. For more unique video expression, VFR(Variable Frame Rate) or Time Lapse/Stop Motion Animation can be produced with DMC-GH4 without postproduction process. In addition, a variety of practical functions required for professional video recording are newly integrated.
REAR CONTROLS
TOP CONTROLS
Panasonic developed new 16.05-megapixel Digital Live MOS Sensor for DMC-GH4 that achieves high quality, high sensitivity image recording with quick response. Approx. 50% higher speed signal readout suppresses rolling shutter effect even when using electronic shutter or recording motion image. The maximum number of recordable images is up to 40(including RAW) / 100 (excluding RAW). Taking full advantage of the Live MOS Sensor, gradation range is expanded by max.1/3 step at low ISO end with fine tuning control by the Venus Engine. Plus, superior noise reduction realizes max.60 min long exposure in B(bulb) mode.
The DMC-GH4 boasts newly developed high-precision, high-speed dual OLED (Organic Light-Emitting Diode) displays for LVF (Live View Finder) and rear monitor. Increasing the resolution of display area to 2,359K-dot, the new 16:9 Wide Screen LVF boasts approx.1.34x / 0.67x (35mm camera equiv.) magnification and 100% field of view and eyepoint of approximately 21 mm. Thanks to the newly designed large eyecup, the visibility of LVF is dramatically improved. The image output between the LVF and the rear monitor is switched automatically with the eye sensor on the LVF, which features options of sensitivity – high, low and off – to reduce false operation during touching on the rear monitor. The 3.0-inch 1,036K-dot free-angle OLED rear monitor (3:2 aspect) with wide-viewing angle rotates 180° to the side and tilts 270° up and down offers approx. 100% of field of view. This rear monitor adopts static touch control for more smooth operation either in shooting or in playback. Both LVF and rear monitor adopts OLED to achieve high speed response with minimum time lag while enhancing the resolution. Notably, the OLED for the LVF in DMC-GH4 boasts 10,000:1 high contrast for superior color reproduction. Now the excellent visibility comes closer to OVF. On the other hand, live view image can be displayed in monochrome through LVF which enables shooting concentrating on contrast.
The image processor Venus Engine is also newly developed dramatically boosting its performance with new quad-core CPU that lets high speed signal processing required for rich video recording such as 4K. The advanced Multi-process NR (Noise Reduction) applies effective noise reduction and edge processing according to each component frequency. Plus, newly added Random Filter granulates chromatic noise to be blended into the image even more naturally. As a result, the max. ISO 25600 is achieved. On the other hand, optimizing the combination design of new sensor, new imaging engine and low-pass filter enhances the limit resolution by more than 5% while suppressing moire. Newly adopted aperture filter is capable of controlling over wider frequency range. It adjusts the amount of sharpness according to the frequency level, resulting in faithful stereoscopic effect. The Venus Engine also improves color reproduction with accurate evaluation of each color even it is similar not only in color phase but also in saturation and luminosity.
To be tough enough to withstand even heavy field use, the main structure of the DMC-GH4 is composed of magnesium alloy full diecast front/rear frame. It also features splash / dustproof construction thanks to the sealing on every joint, dial, and button. The shutter unit that allows max. 1/8000 fast shutter release is also redesigned to be even more durable for approx. 200,000 times release
Even a moment’s waste matters in professional shooting, but it is possible to make target setting intuitively with the GH4. Three dials are equipped on the top and back of the camera and the main dial is now comes with a lock structure. A dedicated button allows direct reach to exposure compensation, white balance adjustment or ISO setting and max.5 settings can be assigned to the Fn button. All these external components are designed to be operated easily without taking eyes off the viewfinder. Both built-in/external flash can be synchronized with max.1/250 second shutter speed.
The DMC-GH4 is also capable of real-time image output to the external monitor in 4:2:2 / 8-bit*3 via an optional micro HDMI cable simultaneously while recording video. Even 4:2:2 / 10-bit is available which is suitable for the professional video making that requires serious monitoring of the footage. Users can choose to output only the recording content or the content with the setting menus individually depending on a display.
Plus, the VFR( Variable Frame Rate) enables recording video with slow/fast motion such as 96 fps, 4x, all in Full-HD[Figure#2]*4. Time Lapse/ Stop Motion Animation video can be produced in camera, too.
The DMC-GH4 is equipped with functions that meets global standard for synchronous video recording. 1KHz Test Tone and Color Bars(SMPTE / EBU / ARIB Standard) are newly available on DMC-GH4. The DMC-GH4 also embeds SMPTE-compliant Time Code either in Rec Run or Free Run count-up methods, which makes it easy to synchronize the multiple video footage or sound source in the post production workflow. Time Code Value can be started at any point of [Reset], [Manual Input] and [Current Time]. Drop frame or Non Drop Frame time code is selectable*5. When recording the video in MOV, AVCHD Progressive, AVCHD or MP4(LPCM), the DMC-GH4 automatically generates multiple seamless files for continuous recording. During playback, the AVCHD Progressive / AVCHD files are reproduced with seamless, interruption-free continuity.
Optional Interface Unit with 2 XLR, 4 SDI, micro HDMi output, color bar signal, audio reference signal, external time control
Panasonic offers an Interface Unit (DMW-YAGH) exclusively for professional/industrial workflow with DMC-GH4 that enables more powerful video transmission. It complies with Full HD (4:2:2 / 10-bit) four parallel outputs and these can be used for 4K (4:2:2 / 10-bit) output – both with time code*1. The XLR input terminals (2ch) are also equipped to connect line or condenser microphone. When connecting with microphone, volume can be controlled for L and R separately, which can be monitored LED audio level display on the back of the unit. The 12V DC IN is highly compliant with large-capacity industrial battery and continuously supplies the DMC-GH4 with power
GH4 MODULE CONTROL PANEL
Output/Input Terminals
The DMC-GH4 comes with a variety of connection terminals for more flexible shooting options. The 3.5mm microphone jack is for high quality audio recording using an external microphone and the 3.5mm headphone jack which enables monitoring the recording audio while shooting video real-time. It is also capable of real-time image output on the external monitor via an optional HDMI micro cable simultaneously while recording video. In addition to these, the DMC-GH4 complies with AV outputs (Audio 2ch, Composite), flash sync terminal and 2.5mm jack for remote controller.
Easy Wireless Connectivity via Wi-Fi® / NFC with Smartphones
The DMC-GH4 integrates Wi-Fi® connectivity (IEEE 802.11 b/g/n) with NFC (Near Field Communication) technology camera to offer more flexible shooting experience and instant image sharing with easy operation. With Panasonic “Image App”, remote shooting of both photo and video* is available by using the smartphone/tablet for a remote shutter with a monitor. Not only releasing a shutter, zooming, focusing and settings of shutter speed, aperture, exposure compensation are all controllable with a smartphone / tablet. All these flexible shooting / browsing / sharing style are made possible with the DMC-GH4 and the Panasonic’s dedicated application software Panasonic Image App for iOS / Android smartphones / tablets. It is also easy to embed geotag in the image after shooting. For the smartphone/tablet without NFC, the camera displays dedicated QR code on its monitor to complete pairing easily by reading the code.
A GN58 powerful External Flash (DMW-FL580L) is newly added to the LUMIX G optional accessories which allows high speed charging of approx.1.7 sec. Not only wireless control but also LED video light function are available. The Stereo / Shotgun Microphone (DMW-MS2) which enables stereo/shotgun switch even allows more precise sound recording with selectable Super Shotgun / Lens Auto / Manual option on DMC-GH4.
[size=+1]GH4 FOOTAGE[/size]
http://youtu.be/hHKJ5eE7I1k
http://www.youtube.com/watch?v=OkAiKENYk3o
[size=+1]MORE GH4 FOOTAGE BELOW[/size]
REAR CONTROLS
TOP CONTROLS
#MIKOS
http://LHOart.com
http://LHOarts.com
http://MIKOS.info
http://LHOarts.net
MIKOS
