Painter - F3 short
Since they are making two versions, one up to 880 for the F35, and the other paired with the F3, I would think it would be in a more reasonably priced range. Either way there's rumblings about third party recorders to cover that. Can't wait to see what options there will be
I think a Nano at 180Mbps I-frame (which is supposed to be master quality even though 4.2.2) is going to be enough for 95% of all shooting situations.
The nano is great, I have it an super quality. The only thing that will hold people backnas far as the f3 goes is the fact that is not 10-bit. Maybe they are working on a 10 bit version; who knows maybe even a 4:4:4 model? That would be awesome
according to the rep I spoke to at the show, he says 8 stops in standard mode (not S-Log) and 11 or 12 in S-Log I believe.
I don' t know how Sony calculates its dynamic range but that would be really low. About the same than the dslr if you get Barry numbers, and well below the af-100 if you take Barry's (provisional) 10.5 stop measurement. It would need the further paid S-log firmware to be good. Until now I did not see any sunlit material, more so on a human being. Everything inside or on grey weather, will just have to wait to get a better idea.
P.s. I don' t understand how people can judge dynamic range in grey weather!!!
Sony said 11 stops before using the s-log. With s-log to increase 640%.
@vcfilms, the KiPro is supposed to be 10bit, also 4.2.2 but ProRes instead of MPEG2. The Nano can't be more than 4.2.2 because of the Sony encoding chips it uses.
The Nano is coming out with an update handling 3D. Wouldn't it be funny if you could hook one up to each HD-SDI and combine them for HDR and 444. Gez, I need to suggest that to Dan at CD.
I completely agree, so I asked him twice if that's right. He then said without S-log it has about the same DR as the ex1, to be honest I just think he was misinformed or didn't know. Either way here's to hoping for at least 10-11 stops without s-log :)
You can't eyeball DR correctly without adequate even illumination. The way Barry tested the AF100 with an illuminated chart is the right way.
Nigel,
I have a fairly mundane question. The protective cover you have over the nanoFlash display, is this a self-frabrication or did you purchase a self-adhesive lexan plate or something similar?
Andrew
I bought a 3" protective self adhesive cover from Vistek. The one's made for DSLR LCD's. It was easier than making my own, and it just about fits. Some people might want slightly bigger, but you can read all the info. After going through 2 LCD's on my Panasonic 7.9 and 17" monitors at over $1000 a pop I'm protecting all the screens, and this screen is a prime candidate to get hit.
I would like to find out exactly where it sits. It felt like more than eight, and I had read some articles where they were talking about more than 13 (probably) in s-Log
Thanks for sharing. I will be really interested to see your NXCAM test when that happens as well!
Pertaining to the Ninja, it also records ProRes (at least that is what they say on their website).
From EOSHD.com
"Sony Japan say their Super 35mm Exmor CMOS in the upcoming F3 is completely new and has pixels which are 4x the size of typical DSLR CMOS ones. Approximately 12 microns sized versus as little as 3 microns on APS-C DSLRs (according to Sony).
The Canon 5D Mark II has a much larger sensor but 22MP. That one works out at 6.4 microns, so even against that beast the F3 comes out with twice the light capturing capabilities per pixel.
This, Sony say, results in 'dramatically increased sensitivity and dynamic range'."
The original Japanese article translated here:
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http%3A%2F%2Fwww.sony.co.jp%2FSonyInfo%2FNews%2FPress%2F201011%2F10-152%2F
This article mentions 12-13 stops of dynamic range:
http://provideocoalition.com/index.php/awilt/story/sony_pmw-f3_announced/
Here is Alister Chapman's (the Sony guru) article:
http://www.xdcam-user.com/?p=1107
The thing about dynamic range is that there is too much variability in how you measure it. It would say 12 stops is probably conservative for the F3 considering the pixel density compared to how other companies are measuring their DR. Fundamentally, the most crucial part of dynamic range is pixel area, the size of the photosite dictates how much electrons you can fit per well. In general, from a sensor perspective, a 3.5k sensor should have better DR then a 5k sensor of the same size.
The problem with DR figures is that it can be gamed, there is no standard method of measuring dynamic range. Companies can pick and choose your DR tests to inflate their claimed dynamic range number for marketing purposes.
Consider that Red used to measure their R1 based on a Stouffer wedge, the newer Epics also use DSC charts, Arri measures the Alexa based on Arri's own DRTC dynamic range tests. dSLR users primarily use Sekonic DR tests. And we don't know what methodology Sony uses for their tests. Even with these tests there is some grey area, a stop or two can be fudged in what we define as a usable stop.
So far we have not seen any footage taken with S-log, which is the only way we'll see the true DR capabilities of the F3. The footage we've seen so far have dynamic range being limited by the gamma curves used since it will clip whites due to highlights not being compressed. Technically, Sony could offer S-log with 12 stops DR on 10bit 422, but being that 12-stops DR S-log is going to look unusable without extensive grading, 444 will be much more ideal.
I would not trust anything said from EOSHD. A lot of the information on that site is just wrong.
Obviously EOSHD has a bias towards DSLRs. However, in this case EOSHD is merely quoting from the Sony site in Japan, which is why I put in the links to the actual Sony site.
And even though Alister Chapman is pro Sony, he tries to give the straight info, just like Barry is pro Panasonic but tries to give the straight info.
I do trust Sony to describe specs on their own products. But the above poster is right, it depends on how the test is run and which test is used.
