PAL/NTSC Selector (only for 1080 50i compatible models): By changing the TV format of the device, shooting in a different movie format is possible.
PAL/NTSC Selector*: By changing the TV format of the device, shooting in a different movie format is possible.
* Only for 1080 50i compatible models. If you switch this selector, it will be required to format the memory card in the setting compatible with the PAL or NTSC system respectively. Also, note that it may not be possible to play back movies recorded with the NTSC system on a PAL system TV.
I have a hong kong (pal by default) a7r. I can switch to ntsc but at the penalty of said annoying "reminder" at bootup every fing time. No way to disable it yet.
This and the redundant double press for mf assist are the two things easily fixed in firmware but not yet.
