P2 vs FS-100
nat2856
I just purchased the HVX200...i did not purchase the P2 . Will the FS-100 give me the same results as the P2 without having the card installed?
The image quality of the Firestore and the P2 cards are identical.
The only difference is the ergonomics, features etc. and P2 cards can use the 720pn modes that will save you disk space.
And you can play back the clips in-camera off the card using the thumbnails; the FS-100 doesn't let you select clips via thumbnail so it's not so easy to know which one to play back.
And you can downconvert on the fly from the card to the tape, which the FS-100 doesn't let you do.
And you can play back your footage on an HD monitor from the card; can't do that with the FireStore.
And you can play back your footage in pN mode right away to see the slow-motion effect that you've shot immediately. Can't do that with the FireStore, you need to pull the footage into an NLE and process it before the slow-mo effect can be seen (although this will change in version 3.0).
