Mike McNeese said:Yeah, do the Mac-format button sequence, and it'll work fine...I use it with a MacBook on a daily basis. Don't expect to edit or even playback footage in realtime, though.
David S. said:I have a 2.0 GHz MacBook with 2 gigabytes of RAM.
I can edit and playback 720/24p footage without issue.
6society said:Hello David,
I am about to take the plunge into FCP. I will be shooting on the HVX using P2 cards. Was wondering if you had any regrets going with the macbook instead of the MacPro desktop. I am having a very difficult time deciding which way to go.
It just seems to me that a macbook will add so much mobility for clients.
Also, do you use an external Raid as a media drive?? If so, which do you recommend??
Lastly, is the DVI port able to output to a monitor to view your edited footage as you go??
Thanks for the quick response,David S. said:We are just experimenting with the MacBook, and are surprised at how well it handles DVCProHD 720/24p captured directly into FCS 5.1.2 to either the internal Hitachi TravelStar 7200 rpm or to the Toshiba 2.5 inch in a bus powered USB2 drive. Very surprised.
