dhollister
Hi guys -
I'm new to the HVX. Did some editing, brought the P2 cards directly into Final Cut 5 and so it worked fine. I'm now possibly working on a different production that isn't as straightforward. So I have some questions.
1) Can you use FCP4.5 with P2? Is it as straightforward in FCP5, with the P2 import option? If not, how do I use P2 in FCP4.5?
2) Can I digitize the P2 footage using FCP5 and then edit those files on FCP4.5?
3) If I offload the contents of the P2 card onto a WINDOWS formatted drive, when I bring that into OS X, will it still import the contents fine into FCP?
Thanks so much.
Thanks so much.
