Eric George
Hello all, I'm having an issue with data on a P2 card and I'm hoping someone can help.
Yesterday I did a shoot with my HVX200 in SD 30p squeeze mode using my two 16gig P2 cards. I have had the camera and cards for a little over 3 years and have had no problems to date.
I formatted both cards at the beginning of the shoot and began shooting. I shot through the first card and the camera rolled over to the second. I continued shooting with no issues, the rec indicator was on, the timer was counting down, all was as it should be. I was shooting some run and gun broll inside so I was powering the camera up and down between set ups but each time it worked just fine all the way through to the end of the shoot.
I use an older G4 mac laptop with the card slot to transfer files to a hard drive and today, when I put the second card in the slot it mounted just fine (the footage on the first card was perfect) but when I clicked on it it showed up as having 0 items. It also says that it has just 9.68 gigs available so I know that the footage is on there. When I dismounted the card and put it back into my camera the camera started flashing a "formatting error" prompt in red. I switched over to vcr mode to try and use the repair clip function but no thumbnails from the footage showed up, only blue screens. I did not flip the write protection slider before putting the card in the computer, but I never have before and haven't had any problems.
I would very much like to find a fix for this problem if possible as a reshoot will be a big pain. Has anyone ever had this issue before and if so were you able to fix it? Or is the card dead?
Any help would be greatly appreciated. Thanks.
