P2 CMS Bug ?
PhantomVideo
Some one tell me if im doing something wrong but
when i use the p2 viewer inside of P2CMS, It works for the first clip,
I close the viewer and select another clip and I get the error msg
"P2 View Failed to open" if i open task manager and end the process
for the viewer it works just wonder if any one else had this problem?
Cheers
I am having problems with P2CMS too. 'Ingest' step seems ok. But when I click the file to playback. p2 Viewer just show a black screen, nothing happens.
also, for footage shot on HVX202, which P2 Viewer should I download? 3.1.2 or 358? thanks
if you want to user P2CMS uninstall p2 viewer, they seem to conflict, i just reloaded a machine cause i couldn't get the preview inside p2cms to work, but
new windows installation, then p2CMS works flawsly :) much happy
camper got to say p2 metadata ROCKS we have had two HVX for a year,
but no p2 cards, this year we could offord p2 cards and a hpx502 exciting times
Use version 3.5.8
I put both of them up at http://panasonic.sixbullets.net but you'll only need the old one if you use a cam with the AJ-YAX800G proxy board.
Right now the programs should still be in beta. I think it's going to be another couple of generations before they start acting like real apps. All the time, I get playback speed issues, sync issues, etc. It seems 3.5.8 might be a little better but I still find myself restarting pretty often.
thanks for the info.
now I can get my P2Viewer working by itself, but P2CMS still can not open P2Viewer. While a friend of mine can get both working. Not sure what is going on. maybe I re-install drivers, viewer too many times. I will try it again. thanks
