P2 card hp hdx16 can't see it
I upgraded my laptop to a new HP HDX 16. Loaded the p2 drivers and everything works fine with the exception of the fact that it can't see the P2 card.
The computer is running vista home premium 64 and I'm using an addonics card bus to pcexpress adapter. The computer sees the adapter and loads the drivers for it with no problem. When you insert the the P2 card in the adapter the computer searches for the right drivers but can't find them.
I've loaded the latest 64 bit drivers and the computer works fine with the HVX 200 and the Hpx500 through the usb port.
I've talked with Panny tech support and was told to run the driver install with the adapter and P2 card inserted. Still doesn't work. Waiting on a call back from them but thought I'd follow up here also.
My first thought is that the problem is the vista 64. I may need to downgrade to XP Pro.
Any thoughts would be greatly appreciated.
