Has anyone actually used OnLocation yet? I have been using DVRack with limited success and am also wondering about this upgrade. I edit with Avid and have had trouble importing files from DVRack into Avid. I wonder if the QTAVID format will remain as an option after Adobe gets their hands on it.
Aloha,
cmus
I downloaded the trial off the Adobe website. Seems you cannot record to disk with the trial but it clearly supports DVCPRO HD. You just need to select the right setting under the devices tab.
just sign in or create an account, then it should bring to directly to the download
https://www.adobe.com/cfusion/tdrc/index.cfm?product=onlocation
I believe they also removed the terrible activation system from SoftWrap, got rid of the update check on startup that you could not disable (and which goes to non-existing servers anyway now that Adobe is in charge),
and there is official Vista support.
The trial version I downloaded also no longer has the QTAVID file format setting. So far, I have been unsuccessful at getting any of the recording formats to work with Avid. Anybody have success with this?
I wouldn't put it past Adobe to pull support for something that directly benefits one of their competitors.
