Mark Smith
I use my Olympus 35-100 Frequently and had an issue lately with soft focus on a particular shot. Afterwards I started poking around with the lens and the camera to pinpoint the issue.
First what I discovered was lens check in the AF was "off" . Even with Lens check off the lens was powered and seemed functional. HOWEVER when I activated lens check and restarted the camera with the 35 -100 lens mounted, the camera powered up and the lens went through some little routine where it made some noises, the focus scale swept through near focus to far focus and settled back to the starting position.
I had looked at a Star chart with focus assist enabled prior to switching on lens check and I looked at the same star chart after switching on lens check and the ability of this lens to focus was significantly better, almost a night and day difference.
For folks using this lens I recommend that you pay attention when the camera powers up with this lens mounted. If the lens does not go through a routine where it sweeps through the focus range before returning to its initial focus setting, you might want to restart the camera and make sure the lens does its thing before you start shooting.
I alos have the 14-35 lens which does seems to function the same with lens check on or off.
