Rick Burnett
Section Moderator
Way to ruin an exciting thread guys![]()
I apologize for getting all technical. I get frustrated sometime when incorrect information gets posted around and then people think they understand what is happening and think they understand how to fix it, and they'll be sadly mistaken when they get in the field and realize no, that's not how it works.
A UV filter does not remove moire, we all know this, it's not a question. I don't want someone thinking that will solve the problem even though a UV filter is good to protect from getting lens scratches!.
A filter that employs diffusion, like the Caprock, works in some cases and not others depending on the lens. I have tested this, I know (as has Barry). The purpose, just as with the OLPF is to spread the incoming light out so it is not sharp (blurry). The interesting part about the Caprock is each of the different sizes use different size and spacial frequency of circles of diffusion with clear areas around them. That is why they each work differently depending on the size of the lens which determines how the actual fine detail gets resolved at the sensor.
Since those of us trying to eliminate Moire and aliasing are tired of guessing which filter goes with which lens at which focusing distances, the goal is to put that diffusion in front of the sensor and after the lens so it can be tuned EXACTLY to the detail coming in, which is what we care about.
I've been using an UV filter on the front of my camera now since I got it, gee, why is there still Moire in my shots :happy:
Be sure to post a link here to the new thread about the results of the new OLPF! I cannot wait to see what you get!
And just because this horse hasn't been beaten enough, a pretty definitive product list for OLPF offerings, look at the offering from Epson:
http://www.epsontoyocom.co.jp/english/application/appli_opt.html
Would you look at that, they offer OLPF that have just IR cut filter OR one that has UV-IR cut filter. Gee I wonder why they off both and they are both called OLPF?
Edit: Oh, it doesn't get any better than this:
http://www.newton.dep.anl.gov/askasci/eng99/eng99312.htm
And I quote:
"An optical low pass filter is a fancy name for a thin transparent sheet that causes a special kind of blurring. The filter blurs the image, but only a pixel or two, and not more than that. This eliminates aliasing and moiré, yet hardly degrades the image. The amount of spreading is chosen specifically for the type of camera."
And this, which is I believe is what these OLPF are using:
"Some digital cameras use a birefringent plate to precisely blur the image. A thin sheet of quartz is used to split or deflect the light according to the polarization. One spot will be split into two spots by the birefringent plate. Then a second plate splits those spots again into a total of 4 spots, all of them a pixel or two apart. The sheet is placed in front of the image sensor. This makes the picture a little blurry and is enough to eliminate aliasing and moiré. Other digital cameras use a clear plastic plate that has dots molded into it to blur the image."
Again, this has nothing at all to do with color. Period. It differences in contrast (detail) between two pixels. But don't take my word for it, ask a scientist
