I'm thinking about using a nikon lens adapter with my GH1, does it change the image at all since there's that dead space between the adapter and lens? i.e. not proper picture, distortion, etc.. I've heard that Nikon glass is the best.
In general adapters that do not have optical elements (no glass in the physical adapter) have not been known to reduce image quality. Mine certainly don't. Adapters with glass may reduce the image quality, but only if you get a low-quality adapter whose glass is distorted/smeared/hazy/blurry etc. Most of the GH1 owners I've interacted with love their adapted lenses. I have a Minolta AF adapter to use a 50mm f1.7 and I can't complain; I love that lens.
a 50mm is a great start, but mind you, on the GH1 it will be 2x whatever the lens is. So the 50mm will really be a 100mm.
But... that's exactly the issue. People think the lens is creating the perspective distortion, and it's not. It's the distance from the subject that creates the perspective distortion. Frame up a face on a 50mm on a full-frame camera, and stand in the exact same position and frame it up with a 25mm on a "2x crop" camera, and you'll have exactly the same perspective rendering. The only time you get distortion is if you try to use a wider-angle lens closer than the field of view would dictate.Try it yourself. Shooting an CU portrait with the 20mm results in slightly unflattering and distorted faces. Put on a 50mm, and suddenly the face looks much nicer. This is because the 50mm is not a wide angle. Only difference is that you would have to step back further to get the same field of view as on a full frame camera.
Use a fisheye, and a telephoto lens, stand in the exact same place and shoot a scene. Then crop the fisheye image down to where it's showing the same field of view as the telephoto, and guess what -- you'll have the exact same perspective! No additional distortion. The perception of distortion with the wide-angle lenses is because people stand closer to the subject when they use them.
The only disclaimer for the fisheye vs telephoto lens example is that lenses with shorter focal distances typically have other distortion characteristics inherent to their design, like barrel distortion, of which a fisheye is an extreme example.But... that's exactly the issue. People think the lens is creating the perspective distortion, and it's not. It's the distance from the subject that creates the perspective distortion. Frame up a face on a 50mm on a full-frame camera, and stand in the exact same position and frame it up with a 25mm on a "2x crop" camera, and you'll have exactly the same perspective rendering. The only time you get distortion is if you try to use a wider-angle lens closer than the field of view would dictate.
A simple way to test it is to use a GH1 with its extended optical zoom feature. Put the Lumix 7-14 on there, zoom to 14mm with EOZ off, and take a shot. Then, with the camera exactly where it was, zoom out to 7mm and turn the EOZ on. The result will be indistinguishable (other than the EOZ shot having slightly deeper DOF due to using a wider focal length). But perspective and distortion and "big nose" effect will be identical, if the camera position hasn't moved.
Actually, this is not the case. A shot taken with an MFT cam + 25 mm lens will roughly have the equivalent FOV of the one taken from the same distance with an FF cam + 50 mm lens (assuming aspect ratios are the same).If you are 10 ft away from your subject, the 25mm will give you a wider field of view than the 50mm at the same distance.
Extended Optical Zoom. On the GH1 it only works in stills mode, and you have to choose a smaller picture size to get the full 2x optical zoom-in effect.What does EOZ do and where do you turn in on?
A 50mm on a "1.0 crop" camera, and a 25mm on a "2.0 crop" camera, when shot side-by-side at the exact same distance towards the exact same subject, will result in exactly the same pictures (in terms of field of view and perspective). But there will be a difference in the depth of field; you would have to account for the DOF difference inherent in the focal length difference. So open up the f-stop 2 stops on the "2.0 crop" camera, or stop down the f-stop on the "1.0 crop" camera, and you'll have absolutely identical images from both cameras.But I still think the 25mm won't replace the 50mm in m4/3. If you are 10 ft away from your subject, the 25mm will give you a wider field of view than the 50mm at the same distance. So if you wanted the same field of view as the 50mm, you either have to 1.) Move in much closer, or 2.) Crop the image shot with the 25mm to match the FOV of the 50mm. #2 is not possible really with video, and #1 results in the dreaded distortion, because now you are that much closer to your subject. Or am I still missing something here?
