***Odyssey 7Q+ or Atomos Shogun with Blackmagic URSA for UHD
NorBro
Major Contributor
Continuing this conversation in a new thread...
In another thread, I recently asked about an adapter that takes one 12G-SDI out and splits the feed into two 3G-SDI inputs.
Answer from Mitch Gross:
"You can use this box:
http://www.bhphotovideo.com/c/search...rch=yes&sts=pi
Why the spec for the output of your camera is up to 12G-SDI, I believe that at this time it is not sending out anything above a 6G-SDI signal. Therefore this box is in fact compatible. The fact that it is from the same manufacturer certainly helps, as it is built to matching specs.
Convergent Design has tested using a Blackmagic Design camera outputting 4K over SDI and through this box to convert the signal into dual-link 3G-SDI. It works just fine.
For anyone questioning why one would want to bother to do such a thing rather than record internally on the camera, take a look at the cost per gig of their media is compared to ours, think about how much you may shoot and decide if this makes the investment worthwhile. Don't forget about all of the excellent monitoring functions we include as well."
I am having a difficult time choosing the right external recorder for a certain purpose.
I am looking to record RAW internally with dual CFAST 2.0 cards, but also have a ProRes backup recording to an external recorder.
I enjoy everything about the 7Q+, but it's recently come to my attention the Shogun may now be able to record UHD via SDI because of BM updating their SDI SMPTE Standard. Has anyone tried the Shogun at least with their BMPC in UHD?
I know that what I am attempting to do (for this job) may not be common, but any thoughts on the matter? Thank you.
Sorry to cross post, but just saw you posted this here as well:
With the URSA, if you set the camera to a project rate higher than 4K30p the camera is outputting a 12G-SDI signal and the camera supports project rates up to 4K60p (the camera always outputs the project rate, not the sensor rate) and has behaved this way since shipping.
The Shogun is advertised as 12G-SDI also, but at the same time only advertises support up to 4K30p which is only 6G-SDI.
The URSA has been compatible with the Shogun since Firmware 2.3 for URSA.
