Mitch Gross
I must admit that the details on the F3 have faded a bit from my memory. I can't quite recall what is and what isn't in the upgrade. I'm pretty positive that you can record the dual-link 1080p60 and perhaps even the 3G single-link 1080p60. If so then that would be the preferred method, using the first of the two BNCs right under the viewfinder. My memory tells me that when the camera is set to 1080i60, the output from these two ports is actually 1080p60. The camera itself always shoots in progressive and it is only to comply with the video broadcast standard that it would strip fields out of the 1080p60 signal to turn it into a 1080i60 to record to XDCAM on the SxS cards.
The Odyssey7Q+ will record 1080p60 in Apple ProRess in HQ, 422, or LT.
The Odyssey7Q+ can be powered from any DC voltage from 6.5-34v. I'm not sure what you mean by a "regular 12v DC cable". The Odyssey7Q+ you rent will need to have cables supplied with it to plug into such power sources. We make them with an XLR4 connector and with a D-Tap connector, both of which are pretty standard for 12v power in the industry. But there is not a big XLR4 power socket on the Odyssey7Q+ like there is on the F3 camera body, that would be a huge chunk of real estate on the Odyssey7Q+ housing. We use a small Neutrix connector, which is why we make a variety of cables to plug into accessor power ports.
