Nx! Msm
Movie standby mode shows what you will capture when recording a video. It'll display any differences you've made to gamma and corresponding adjustments. Live view seems to be optimized for photos
Ahhh - I was thinking there was a setting for pre-capture that I hadn't discovered.
Yes, I use it all the time. ALL the time. There's a massive leap in the image from still setting to video, and you don't have the framing without it. It stays in that mode between clips so no worries for me.
Also, if you have DIS enabled, you'll see the image enlarge due to the sensor crop - if you move from, say, handheld to a tripod and pop into standby mode and the image jumps up in size, it's a reminder to turn DIS off, since (far as I know) the camera doesn't have icons for OIS and DIS like broadcast and dedicated video cams do.
If you go to Photo Size and click on 23.6m (6480x3648) you will have the 6x9 and there wouldn't need the Movie Standby Mode.
