Does this computer work fine for GH2 editing?
http://www.notebookreview.com/default.asp?newsID=5813&review=asus+ul20+ul20ft+ul20fta1
Actually, I'd upgrade to a 7200 speed card disk. But the unit I found has 3GB memory RAM. Could it be enough for solving those "deficiencies"?From the specs:
Intel Core i3-330UM (1.20GHz)
Intel Graphics Media Accelerator HD integrated graphics
2GB DDR3 RAM 1066MHz
320GB 5400RPM hard drive
With a 1.2 ghz processor, it will work but it is going to take forever to render something out. The 2 gb of RAM, is going to choke out. The 5400 speed hard disc, works and with the other deficiencies, you wouldn't notice the benefits of a faster hard drive if it had one.
Wouldn't Intel® Core™ i7 640UM (4M Cache, 1.2 GHZ with 2.266 GHz Max Turbo Frequency) - Overclockable be enough?- i5 or better i7 with decent Mhz (1.2 is terribly slow, realtime work on video doesn't take advantage of multiple cores - only rendering does)
I will be using external monitor as much as possible. However, there will be situations where I need a small package/LCD too.but on top of it, try to do a sketch (or a photoshop crop) of how premiere or whatever will be used will look like in such a display, showing an output monitor smaller than a credit card..
Isn't 2.26 enough for 1080/24p editing?for sure it's among the best small laptops, but it's not only a matter of pure Mhz.
2.26 it's the peak
there's not a yes/no answer.Isn't 2.26 enough for 1080/24p editing?
Ya, same wondering here. I am thinking to buy a MacBook Pro 17-inch though. Will the best configuration be enough?I have 2009 13'' Macbook and I'm planning to expand it's memory capacity to 4GB. I'm also getting couple of 1TB external hard drives. Is this system enough to edit 1080p/24p? I'm gonna use my 50'' plasma-TV as my monitor.
