Hi,
Has anyone using the hvx 202, find the camera noisy? The one i am using is noisy, the gain is set to 0, is there anyway to reduce the noise in the camera?
I also found this to be true...I had all settings set at 0 and played around with each settings to see if it made a difference but it didn't. I find that the camera did not hold well at all in low-light compared to even the DVX. I didn't get much prep time though but I still couldn't find a solution.
What monitor are you viewing your footage on? Most HD LCD monitors add precocious amounts of noise not in the original signal. Try to watch the HVX footage on a DLP projector or HD CRT if you want to see the true nature of the image. Even the 17" BTLH Panasonic adds noise.
