Noise/ISO comparison
Barry_Green
Moderator
After much talk about the low light advantages that DSLRs offer, and a recent discussion about noise versus sensitivity, I decided to see how the wide ISO range of the 7D and GH1 compare, as for overall sensitivity and noise performance, against a conventional video camera with reasonably good low light performance (in this case, the HPX170).
I tweaked them all to give what I figured would be good noise performance; I took the sharpness down on all of them, I used the 320/640/1250/2500/5000 ISO's on the Canon, I boosted the coring up and used B.Press on the HPX170, and I used the GH1 in fairly neutral settings, 320/640/1250 ISO, with sharpness down.
Then I shot a chart (oh yes, a chart again!) at various ISOs, changing the shutter speed to keep the overall exposure the same (so, 320 ISO @ 1/60, 640 ISO @ 1/125, 1250 ISO @ 1/250, 2500 ISO @ 1/500, and 5000 ISO @ 1/1000, and 6400 ISO @ 1/1250). I did the same thing with the video camera, using 0dB of gain @ 1/60, 6dB @ 1/120, 12dB @ 1/250, and 18dB @ 1/500.
Which means, basically, if I translated the video camera's base ISO plus gain, it could be said that I was testing the video camera at 500, 1000, 2000, and 4000 ISO.
The DSLRs employ some pretty aggressive noise reduction, especially the GH1, and it's effective. At 320 the noise is pretty minimal, and even at 640 the noise is a less than the video camera at zero dB. I think the GH1 at 1250 ISO compares favorably, strictly on a noise-performance basis, with the video camera at 500 ISO.
From that point on, though, they pretty much trade places, and are much closer in noise performance than I ever would have expected. When you compare noise for noise, ISO against gain, they look pretty evenly matched. Far more evenly matched than I would have thought.
So -- judge for yourself, I've arranged them in what I consider ascending order of noise performance. Test subject was the grayscale portion of the Billups VF/X 1+ chart from DSC Labs, cropped and extracted and blown up to 200% size for easier exhibition of the noise.
Note: this is not a "low light" test, this is "how does the sensitivity compare, along with the grain?" In some ways you could look at it as a low-light test, but both DSLRs were at f/5, the video camera was at about f/4. The SLRs could open up another half-stop, but the video camera could open up another two and a half stops. Then again, the SLRs could have f/1.4 lenses on them, if we don't want to compare stock lenses, so ... no, this isn't a "low light" test. This is just to see how the noise and sensitivity compare, to see if there's some big advantage in the new DSLR technology.
Be sure to watch it full-screen, to exaggerate the noise patterns and see the differences.
[moviehd]7a96d5b51511e1c5f5[/moviehd]
What was the noise reduction setting on the GH1 at? You said you reduced sharpness, what about NR? I usually shoot -2 (more noise.)
I actually had it at zero. I could have gone to +2, which would have been more fair with the HPX170's coring +7 setting. But in general use I normally run it at -2, so I kind of just punted and went with zero. It's really clean anyway. At least as far as crawling noise goes.
There's a second part to the test involving the CamBelles and the picture turning to oatmeal, but it's a lot harder to quantify (because downrezzing makes everything look better, so you're not seeing what's really happening).
Barry thanks for more tests, just one question. I know this isn't a 'low-light' test, but in what other situation would these noise sensitivities crop up? (The reason I'm asking is, okay the video camera may do better at extremely high ISOs, but wouldn't the DSLR wide open be able to go into darker situations with less ISO in the first place?) Is there somewhere else where the way these cameras handle and produce noise becomes an issue?
Well, like everything, "it depends". The video camera, zoomed out to wide angle, opens up to 1.6. You're going to be pretty hard-pressed to find an f/1.6 wide-angle lens that matches what the video camera can do. But, then again, the relative sensitivity of the video camera isn't necessarily a linear performance curve...
At an equiv. of 50mm, the video camera is going to have a max opening of, oh, maybe around f/2.0. The DSLRs, with their stock lens, are going to be at f/4 or f/5. But you could replace the lens with a wide-open f/1.4 type of lens and get a lot better performance.
I guess all that's going on here is that the DSLR is claiming ISO 1600 or ISO 5000, and the video camera just has "gain", but -- when it all comes down to it, they're not that different. They all perform about the same, noise/sensitivity-wise.
The GH1 doesn't get grainy/noisy like the others, but its image goes soft and the color saturation goes down the tubes. I'd stick with 800 or lower on the GH1 whenever possible.
I guess I was just really surprised; we always complain horribly about "gain" on video cameras, and people trumpet the "great" low-light capabilities of the DSLRs, but when you get right down to it -- they're about the same.
Barry, thanks. I am travelling and only have my iPhone so I cannot view the video, but you indicate two different patterns of degradation so which of them is better rescued in post using normal tools, and using a noise reducer plugin (without getting a plastc look). GH1 or the pack of other cams?
Barry, a second question. In your opinion how much of the perceived low light dSLR video advantage is due to aliasing covering up noise? And if that is what is happening will the viewer perceive an advantage not visible in charts? Does this give the 7d with it's greater aliasing a perceived advantage over the GH1?
When I've somewhat sloppily mentioned that HDSLRs 'are better in low-light' I've always meant with a 35mm adapter on the video camera for shallow DOF images. How does the 170 + 35mm adapter fare in a test like this?
I appreciate your tests, even though in this one the compression was so bad that I didn't see any noise at all, just big blotches. I had to assume you had put the shots in the right order because based on the web footage I wouldn't have been able to.
We all know that small sensors produce more noise. And yet there are compact photo cameras that shoot essentially noise-free images. How can this be? Well, because they noise reduce the heck out of the images. And it shows, because the resulting photos look like watercolor paintings.
Would you notice the watercolor look on a test chart with a bunch of solid colors? No, you wouldn't.
I don't see how a small sensor could possibly keep up with the noise performance of the larger sensors unless it uses significant noise reduction. Isn't this what physics dictate?
But Barry, wouldn't a video camera and DSLR, both at F1.4, both at the same ISO have different low light performances due to the size of the sensor?
Maybe that’s the point he’s making….that it's not necesarily just the sensor size and that if these video cameras had the ability to exchange lens like these DSLRs then the differences in low-light ability would not be that far apart (or maybe I’m way off).
Well, most of the video cameras go pretty open as far as their apertures, so I'm not sure the lenses would make that much of a difference. It sounds like he's saying there isn't much of a difference period, which is what I'm trying to verify...
Oh, I'm certain that in that case, the DSLR would slaughter. Most adapter require the video camera to zoom in, thus losing some of their wide-open advantage, and then there's at least a half stop of light loss from the adapter, and then cumulative light loss from the lens on the front.
For shallow DOF purposes, no question, the HDSLRs rule the roost.
even if cams are technically smilar there is a big price difference.
Unquestionably.
I'm not trying to "prove" the "superiority" of the video camera here. I'm just trying to bring perspective to the situation, is all -- how much of an improvement is there, if any, and if there is any, WHY is there any? That's what I'm interested in.
No, the compression doesn't affect it at all. That's why I did it the way I did it -- I blew up the scene to4x size to exaggerate the size of the noise. What you're calling blotches is the actual noise, just blown up 4x. I extracted an SD-sized patch out of the HD frame, then blew that up 4x.
Watch it in full-screen. Anything you see that is moving at all in any way, is noise.
Small pixels do, yes. Not necessarily small sensors.
Yep -- there is huge, massive amounts of noise reduction going on in the SLRs, primarily in the GH1 (and that was with NR set to middle, not even +2).
If the pixel count was the same, I'd agree with you. But in this case, the actual pixel size is pretty much the same between the two sensors. The HPX170's pixel size is about 5.5 square microns, the 7D's pixel size is about 4 microns. Then you have to factor in CCD vs CMOS, and active noise reduction vs. not so much, and spatial offset vs. pixel binning...
Why would they? ISO = ISO, whether you're talking about a 1/6" video camera or a frame of 35mm film, if the rated sensitivity is the same, the sensitivity should be the same.
The noise/grain may differ, but the sensitivity will be the same (and that's really what I wanted to test here, was noise at sensitivity levels).
