I think Dasbin means the gradient lines inherent to the compression algorithm, not color banding or FPN?
FPN is always present and looks like faint dark checkerboard pattern across whole frame.
Color banding looks like purple or yellow streaks that somewhat follow the same pattern as FPN but is only present in -2.5 or less underexposed video. Sometimes it's all over, sometimes it's just in certain areas of the frame. The more contrast in the picture, the less banding problem you have generally. This is why sometimes it happens and sometimes it doesn't.
Gradient lines occur on surfaces that are smooth and uniform in color/texture and generally follow the radius of light-to-dark transitions. This seems to happen regardless of the above problems and regardless of bitrates.
Just to clarify, I am speaking purely of FPN and not at all about compression. I have never seen color banding that to me looked like it was something other than a manifestation of FPN. I'm curious what you mean by "somewhat follows the same pattern as FPN." I think that maybe the reason you can sometimes see color banding but not general FPN in video footage is because the processor is removing evidence of the rest of the FPN through noise reduction.
I mostly shoot in, and run my tests in, RAW stills, to see what the sensor is really doing and try to remove processing and compression from the equation. But I still think there is some noise reduction being done even in RAW mode. My theory is the camera has a constant "dark frame" reference (seperate from the one it takes during long exposures) which it subtracts from all images. I don't have any evidence to back this up unfortunately, but it would explain a few things, including why some people claim FPN/banding gets better over time with their camera, and why there is so much more FPN viewable during live-view in certain situations than in the actual recorded file. But that one may just be due to different sensor read mode.
