nobbystylus
Just did a multi cam shoot, 3 cams - Sony Z1 shooting HDV (mostly wide open, but some shots stopped down to 4.0), HV30 shooting HDV (in cinemode, exposure down to about -4) and GH1 shooting full HD 1080 25p, 1/50, 400iso (with stock lens wide open at f4.0). Clearly the GH1 has the nicer visual image. But i'm so disturbed by the noise and banding in the GH1s image that is only just slightly underexposed that basically i'm having to cut around the GH1 stuff almost entirely. This is certainly a result of being a bit underexposed, but if i upped the iso ( to expose correctly) it got much much worse.. Also, the noise is so much less of an issue on the HV30 (in cinemode) that the GH1s buzzy wavey lined noisey blacks are almost an embarrassment. Yes i can denoise, yes the image is nicer, but its at 400 iso and it looks soooooo sooo messy. Buzzy buzzy noise all the way through plus that awful banding. The Z1 is clean, the HV30 is a bit noisey, but the GH1 has banding, low light noise and serious amounts of zig zaggy / wiggly noise AT 400 ISO!!!
This is using the ipowell hack also, so can't be a codec issue.
I'm wondering if i can really get a clean low light image with dark backgrounds with this camera? I've shot stuff at Iso 100 and its still had noise... maybe its a faulty unit?
