ahalpert
Major Contributor
Yes, I can say that. Maybe you have decided that you can be less precise about focusing in HD than you need to be in 4K because you don't think it will be noticed. I cannot say that for my own work. Either the focus is correct or it is not. Read my previous post above about how NOTHING is different about the camera or lens when you change from a 4K codec to an HD codec. Nothing. Resolution makes no difference and the techniques and tools you use to achieve focus are exactly the same. Either you got the focus right or you didn't. But I will agree there are different degrees of missing the focus and some might slide by.
Sure, the process and goal of focusing is the same regardless of resolution/viewing size (which is really just depth of field, since DOF is affected by the viewing format)
But I think that what changes is the keeper rate and therefore the required number of takes and the effort for quality control. If you were shooting nature footage in 16K for an IMAX screen or something, you might have no choice but to lug your field monitor out to basecamp so you could check your footage before coming home from the bush to make sure you had enough usable shots. Your process might be good enough for 4K, but you might need a different workflow to deliver at some more demanding DOF? Which is one advantage that AF has, being that the computer can evaluate the full resolution of the image and adjust to it more frequently than the human.
I mean, people commonly stop down to give themselves a greater margin of error on difficult focus pulls. Or, I work with a photographer who regularly relegates shots she wanted to print large to "Instagram only" because of small focus errors or motion blur only seen when blown up. And if she's shooting a performance for Instagram only, she might crank the ISO because the noise will be less visible, and go for a fat stop to try to get the whole stage in acceptable focus. If she's going for a blow-up, she can't afford such a high ISO and has no hope of achieving adequately deep focus, so shifts the strategy to finding an ideal stop for selective focus of a single dancer but not too shallow. Two divergent focus strategies, and focusing 1/3 from foreground subject to background subject if you want to evenly spread the DOF.
And clearly there's usually a lower standard for focus accuracy in TV than in film, which equates to doing fewer takes or accepting imperfectly focused takes for the benefit of the preferred performance.
So, it doesn't seem crazy to me for someone to say, "Well, I could hack it at 4K, but now that we're shooting 16K I'll get a higher keeper rate with AF"
